Script bindings to outputs are not working
  • Script bindings to outputs are not working
  • GavinHe
    GavinHe
  • sesa116379_brid
    sesa116379_brid
‎2018-09-06 02:13 PM
Last Updated: Sisko GavinHe Sisko ‎2023-01-25 07:21 AM
When binding Output points in the script editor to the desired outputs, the bindings are not working.
  • EcoStruxure Building Operation All Versions
  • Automation Server
  • Central I/O Modules
When bindings to the output points the incorrect attribute is being used.
  1. Open binding editor for the desired program.
  2. In the right hand pane, choose the desired output to be bound.
  3. Expand the point and select Requested Value.
  4. Drag the Requested Value to the desired output in the program.
  5. Save settings.
Tags (2)
  • 4444
  • GavinHeward23
100% helpful (1/1)
