Schlage Integration with PIN
  • Schlage Integration with PIN
  • Derrick_Ratliff
    Derrick_Ratliff
  • Roger_Bently
    Roger_Bently
‎2018-09-06 08:41 AM
Using PIN only for the Integration and it is not working.
Continuum Version 1.94 and above.
The X Driver has a limitation on how it functions with PIN only.
To resolve this issue, DO NOT use PIN only as it is not supported by the X-Driver. If the PIN needs to be used then it must be Card and PIN.
  • 18453
