Satchwell BAS 2800+ Operating System Compatibility
  • Satchwell BAS 2800+ Operating System Compatibility
  • CraigEl
    CraigEl
  • DavidChild
    DavidChild
‎2018-09-10 01:09 PM
Last Updated: Administrator CraigEl Administrator ‎2025-11-04 10:15 PM
Is the BAS2800+ software compatible with Windows Vista, Windows 7, or newer operating systems?
Satchwell BAS & Sigma
Satchwell BAS 2800+
Customers may attempt to install BAS2800+ versions 2.9 or 2.10 on modern Windows platforms. Clarification is needed regarding supported environments and potential risks.
BAS2800+ versions 2.9 and 2.10 have been officially tested and supported only on the following operating systems:
  • Windows NT
  • Windows 2000
  • Windows XP
  • Windows Server 2003
The software has not been tested or validated on:
  • Windows Vista
  • Windows 7
  • Windows 8
  • Windows 10
⚠️ Important Notice:
Installing BAS2800+ on unsupported operating systems may result in unpredictable behavior. Schneider Electric does not guarantee functionality and will not accept liability for any issues encountered.
Recommendations
Preferred Option
  • Install BAS2800+ on a physical machine running Windows XP or Windows Server 2003 for full compatibility.
💡 Alternative Option: Use a Virtual Machine (VM)
If a legacy physical system is unavailable, consider running BAS2800+ inside a virtual machine configured with a supported operating system.
⚠️ Note: While this method can be effective, it is not officially supported or tested by Schneider Electric. Use at your own discretion.
Additional Notes
  • The BAS2800+ product was discontinued in 2008.
  • No further updates or compatibility testing will be conducted for newer operating systems.
  • Satchwell BAS & Sigma
Tags (2)
  • 11322
  • CraigEllis25
