STR-250 functionality on Micro Regulators (MR).
  • STR-250 functionality on Micro Regulators (MR).
‎2018-09-10 05:32 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:57 AM
Does the STR-250 work on Micro Regulators (MR)?
I/NET Seven
STR-250, I/STAT, M/STAT
I/SITE Controller and Micro Regulators (MR)
The STR-250 Wall Module is the replacement for the commonly referred to I/STAT sensor, still referenced in I/NET documentation.  The I/STAT is no longer available.
The STR-250 sensor is the replacement for the I/NET I/STAT, so installation and configuration for the STR-250 is as per this I/STAT. There are two documents that will provide assistance with this TCON126 and TCON299 (Chapter 21).
The STR-250 full functionality must be installed on the I/STAT port of any I/NET device and configured as detailed in the above documents. Only one I/STAT port exists per MR.
The M/STAT is still available and is used as the hardware tool for configuring the controller settings on all supported I/STAT devices, such as, all Micro Regulators (MR) variants, I/Site LAN Controller (Model 7728) and Xenta 102-AX.
Labels (2)
  • TAC INET
Tags (2)
  • 6746
  • thermostat
