SSL and Graphical Programming
  • SSL and Graphical Programming
‎2018-09-11 12:28 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:57 AM
Issue1:
Unable to use some of the function blocks in the Graphical Editor when creating a graphical program.
Issue2:
Unable to find some of the function blocks in the Graphical Editor
EcoStruxure Building Expert
SmartStruxure Lite Multi-Purpose Manager
Description of each function block is not available in Building Expert
Resolution 1:
A detailed explanation of each function can be found in the StruxureWare Building Expert Graphical Block Programming User Guide.
Resolution 2:
Upgrade MPM firmware to 2.16
  • EcoStruxure Building Expert
Tags (2)
  • 17912
  • lua
