SQL Server Management Studio fails backup process with "Status = 112" error
  • SQL Server Management Studio fails backup process with "Status = 112" error
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 12:47 PM
When backing up the Continuum Database using SQL Server Management Studio the backup fails.  SQL indicates Status = 112
Continuum
SQL
DB Backup
Insufficient disk space to hold backup file.
Remove files from hard drive to free up a sufficient amount of storage space.
  • 7144
