SQL Server Implicit conversion from data type datetime to int is not allowed
  • SQL Server Implicit conversion from data type datetime to int is not allowed
‎2018-09-11 06:54 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:57 AM
An update from 1.94 to 1.94 SP1 will generate an "Installation error! Microsoft ODBC SQL Server Driver SQL Server Implicit conversion from data type datetime to int is not allowed. Use the CONVERT function to run this query."
Andover Continuum
  • Continuum
  • Windows XP
  • Windows 7
  • Windows Server 2003
  • Windows Server 2008
A column in the db doesn't get converted properly SQL Server Implicit conversion from data type datetime to int is not allowed Use the CONVERT function to run this query.
To correct this issue apply the following hotfix AFTER installing 1.94 SP1 but BEFORE running the database update
Hotfix for DataBase Update Error
  • 15299
