SQL Server Failed to Initialize when Trying to Run Reports
  • SQL Server Failed to Initialize when Trying to Run Reports
  • sesa139513
    sesa139513
  • Roger_Bently
    Roger_Bently
‎2018-09-06 03:09 PM
When Reports are opened and the user selects a Report then tries to run the report, an error comes up that says “Server Failed to Initialize” and nothing happens.
I/NET Seven Site
error comes up that says “Server Failed to Initialize"
There is a fix for this but an IT individual will need to be present or the user must have admin rights to do this.
  1. Shut down I/NET and Seven Reports.
  2. Go to Start, Run and type Regedit at the prompt.
  3. Go to Local_Machine, Software, Microsoft, MSSQL Server, Super Socket Net Lib.
  4. Expand this and there should be two folders listed in here, NP and TCP.
  5. Highlight the Super Socket Net Lib and a Protocol file appears.
  6. Right Click this file and modify it to display the Hex addresses in there and verify that one exists for NP and TCP.
Value data:
0000 74 00 63 00 70 00 00 00 t.c.p...
0008 6e 00 70 00 00 00 00 00 n.p.....
0010
Note: If you are not sure please contact an IT professional to assist you.
  • TAC INET
  • 1834
