SPP110 Pressure transmitter Wet media wiring identification
  • SPP110 Pressure transmitter Wet media wiring identification
  • CraigEl
    CraigEl
  • PeterEdvik
    PeterEdvik
  • Gary
    Gary
  • SESA150559
    SESA150559
‎2018-09-11 03:56 AM
Last Updated: Gary Schneider Alumni (Retired) ‎2022-11-09 04:53 AM
Wire colour coding for the SPP110
Field Devices
  • SPP110:
  • 004702020
  • 004702040
  • 004702060
  • 004702080
  • 004702100
  • 004702120
  • 004702140
Wire colour coding SPP110 required.
Due to supply problems, between week 23 to week 32, there was a change to the sensor's cable and the wire colours. This was implemented by the manufacturer without Schneider Electric's knowledge. So no product announcement was produced.
                     Original       Week 23 to Week 32
No. Function Colour                Colour
1     Y            Brown                Green
2    GO         Black                  White
3    G            Red                    Brown
Standard        Week 23 to Week 32
Refer to the SPP110 Pressure Transmitter Wet Media Specification Sheet for more information.
The SPP110 installation sheet showing the standard wire colouring is available here
The SPP110 installation sheet showing the wire colouring is attached.
  • Field Devices
Tags (2)
  • 13363
  • GaryMontague22
100% helpful (4/4)
