SP-AC1: Card read valid but door stays locked - Continuum transition
  • SP-AC1: Card read valid but door stays locked - Continuum transition
  • RandyDavis
    RandyDavis
  • JamesMorgan
    JamesMorgan
Lieutenant JG JamesMorgan Lieutenant JG
‎2022-08-03 10:55 AM
on ‎2022-08-03 10:55 AM
  • After transitioning SP-AC1, hardware does not respond to manual commands.
  • SX Client shows a valid read and shows the lock has been activated but the hardware does not change state (locked or unlocked)
EcoStruxure Security Expert
Security Expert
  • The reader module type configuration did not transfer during the transition
  • In Continuum, IOU modules (in Listview) show ProgramID value is empty/blank when it should have firmware version and module type
  1. In Security Expert, go to Programming|Outputs|General Tab
  2. Select irresponsive Module
  3. Change Address Module Type from <None> to <Reader(RD)>
  4. Save changes
  5. Test card read or manual lock
  • EcoStruxure Security Expert
  • JamesMorgan22
