SE8000s and SE7000s unable to use Zigbee
  • SE8000s and SE7000s unable to use Zigbee
  • RandyDavis
    RandyDavis
  • JonGreen
    JonGreen
Commander JonGreen Commander
‎2021-10-27 08:19 AM
on ‎2021-10-27 08:19 AM
SE7000s (all) and old hardware SE8000 (firmware <= 1.7.4) won't support EBO Zigbee.
  • SSL SE7000
  • SSL SE8000
EBO Zigbee has Standard and High-Security levels. The SE7000s and old hardware SE8000 (firmware <= 1.7.4) only supports Zigbee Low Security.
Replace the SE7000s and SE8000s old hardware using SE8000 with the current hardware that supports firmware 2.0.0 and newer.
Tags (3)
  • JonGreen21
  • security
  • zigbee
100% helpful (4/4)
