SE7200 handling simultaneous applications
  • SE7200 handling simultaneous applications
  • SESA150559
    SESA150559
‎2018-09-06 12:49 PM
Want to be able to run the SE7200 in floor heating and chilled beam simultaneously.
SE7200
running simultaneous applications.
Unfortunately the SE7200 will only handle 1 main application per controller due to its limited I/O.
Labels (2)
  • EcoStruxure Building Expert
  • Field Devices
  • 7065
