Running I/NET on a Virtual PC.
  • Running I/NET on a Virtual PC.
  • Chris_Asbury
    Chris_Asbury
  • Roger_Bently
    Roger_Bently
‎2018-09-06 12:37 PM
Installing I/NET on a Virtual PC and how to get it to work properly.
  • All versions of I/NET
  • Server 2008R2 (64bit)
  • Server 2003
  • Windows 10 64bit (Inet 2.49 only)
  • Windows 8
  • Windows 7
  • Windows XP
  • SQL versions 2005, 2008
  • VMWare
This is an unsupported application as I/NET was not tested in this environment due to the various operating systems that are out there.
This is a use at your own risk, it works in most instances when set up correctly but if for some reason it does not, it is an unsupported application.
  • TAC INET
  • 7405
