Running I/NET Seven with a "User" group
  • Running I/NET Seven with a "User" group
  • RobertAndriolo
    RobertAndriolo
  • Tom_Poovey
    Tom_Poovey
‎2018-09-10 08:55 AM
Last Updated: Picard RobertAndriolo Picard ‎2021-03-02 10:02 PM
  • How to run I/NET Seven Software as a local user
  • Customer does not WIndows User logged in with Local Administrator rights to run I/NET Seven Software
TAC INET
  • Windows 7
  • Windows 10
  • I/NET Seven Rev 2.41 and above
The IT department requires that I/NET Seven runs using a Windows "User Group" instead of the usual "Local Admin"
Define the Windows User Account
  1. Temporarily log into the PC with the desired User account using “Local Admin/Administrator” rights.
  2. Turn off the “User Account Control: (UAC) following the directions defined in this article Windows 7/10 User Account Control Settings
    If this is not done then every time you try to enter an I/Net editor, using the “User” Group you will be asked to login as a “Local Admin”
  3. Change the User account back to the "User" Group
I/NET Seven Feature Matrix:
Review the following table showing all the editors both the “Local Administrator” and the “User” can access with their “Windows” Rights.
  • Note: **The I/Net Editor “DbCreate Functions”. If you log into "DbCreate with the "SQL Server Authentication" then these items will be "Y". If you do not give the "Windows User" the SQL Username and Password then these items will be "NO"
  User Account
I/NET Seven Operation Administrator  User
Install I/NET Y NO
Remove I/NET Y NO
Upgrade I/NET Y NO
I/NET Configuration Y Y
DBCreate Functions
Create db Y Y **
Import I/Net 2X Y Y **
Verify existing db Y Y **
Remove existing db Y Y **
Backup db Y Y **
Restore db Y Y **
Import Docutrend Archive Y Y **
Upgrade db Y Y **
Seven Reports
View Y Y
Run Y Y
Configure Y Y
Save Y Y
Print Report Y Y
Mount Archive Y Y
View Archive Y Y
Run Archive  Y Y
Print Archive Report Y Y
Archive Configuration
Event Archive Configuration Y Y
Run Y Y
Trend Archive Configuration Y Y
Run Y Y
View  Y Y
I/O Server Configuration
Promote Filemaster Y NO
Demote Filemaster Y NO
Promote Client Y NO
Demote Client Y NO
  • TAC INET
Tags (4)
  • 7494
  • groups
  • inet
  • RobertAndriolo21
