Running Access Expert Reader Modes Report
  • Running Access Expert Reader Modes Report
  • Ramaaly
    Ramaaly
Lt. Commander Ramaaly Lt. Commander
‎2023-07-07 06:09 PM
on ‎2023-07-07 06:09 PM
The Reader Mode Report shows the readers configured for the instance. The report will show the reader if the reader is running in the online access method, if the reader has a programmed reader mode, the schedule associated with the reader mode, the action and access method of the reader mode.
EcoStruxure Access Expert
Access Expert Hosted V3
Documentation does not detail the steps to run a Reader Modes Report
To run a Reader Modes Report
  1. Select the 'Access Control' Tab.
  2. Select the "Reports" Button.
  3. Select "Add Report".
  4. Double-Click "Reader Modes Report"
  • EcoStruxure Access Expert
  • RamaAly23
