RoamIO Infinet Service Tool does not show devices.
  • RoamIO Infinet Service Tool does not show devices.
  • AbeMeran
    AbeMeran
  • BillNeville
    BillNeville
‎2018-09-06 12:14 PM
RoamIO hardware shows activity on the TXD and RXD LEDs on the RS-485 lines but after login in with user name 'acc' and password 'acc' no devices are shown on the tree.
RoamIO
The password of the controllers ACC user has been changed from the default.
The Infinet Service Tool does not generate an error to indicate it has failed to login to the controller. This is a defect in the tool itself and has been reported as such.
Use one of the suggestions below to resolve the login issue.
- Use the correct ACC password
- Use a different controller user for which you know the user name and password
- From CyberStation reset the user's password.
  • 8142
