Reset System Plug-In original pane layout
  • Reset System Plug-In original pane layout
  • PeterLarsen
    PeterLarsen
‎2018-09-06 02:02 PM
How do I reset the view of the System Plug-In  to the original look.
System Plug-In
They folder pane has been modified and now the default layout is required.
A reset to default will be required to get the original settings
These steps will reset the view to default
  1. Open the System Plug-In
  2. Under the file menu select Default Settings
  3. A message will appear that "The command requires a restart to take effect."
  4. Shut down the System Plug-In
  5. Restart the System Plug-In  with the original default setting is applied
  • 4759
