Required list of URLs/Ports to be whitelisted under firewall/network for EcoStruxure Building Activate (India Only)
  • Required list of URLs/Ports to be whitelisted under firewall/network for EcoStruxure Building Activate (India Only)
  • Mukesh_Sangwan
    Mukesh_Sangwan
Ensign Mukesh_Sangwan Ensign
‎2025-04-15 05:12 PM
There is a need to identify the Ports, URLs and Static IPs which must be open through customer's firewall for EcoStruxure Building Activate Flex Server and Partner Portal
  • EcoStruxure Building Activate Flex Server
  • EcoStruxure Building Activate Partner Portal
Ports, URLs and Static IPs list needed to create firewall exceptions for EcoStruxure Building Activate Flex Server and Partner Portal in order to keep them functioning correctly.
Below are the list of ports, URLs and static IPs that must be open through a site's firewall/network:
URL Port Protocol Usage
https://sentry.zenatix.com
443 TCP Allows the gateway to upload error logs and diagnostics.
https://router.zenatix.com
443 TCP Allows the gateway to download Linux & Python updates from the Zenatix Server. Regularly polls the Zenatix Server to check internet connectivity.
https://timesync.zenatix.com
9090 TCP Time server allows the gateway system & gateway clock to remain synchronized with Zenatix Server.
https://gitlab.zenatix.com
443 TCP Used for troubleshooting to update the gateway codebase from the Zenatix Server.
https://telemetry.zenatix.com
443 TCP Used for sending IoT device data and gateway health data to the Zenatix Server.
https://emqx.zenatix.com
8883 TCP Used for communication between gateways and Zenatix cloud services for getting configuration or alarms from Zenatix Server to gateway and vice versa.
54.169.200.193 1194 UDP Allows Zenatix to remotely access and do API calls to the gateway through OpenVPN.
https://mender.zenatix.com
443 TCP Used to download firmware updates to gateway from Zenatix Server.
Note:
For the list of URLs to be whitelisted for the Global Portal, please refer to Required list of URLs/Ports to be whitelisted under firewall/network for EcoStruxure Building Activa....
  • MukeshSangwan25
