Report Display too small.
  • Report Display too small.
  • Roger_Bently
    Roger_Bently
‎2018-09-06 12:27 PM
Report when previewed appears in a very small square on the screen with unreadable characters.
All versions of I/Net Software.
The default printer is set to a badging printer.
To resolve this issue the following steps should be followed:
1. Check the Printer Setup for Seven Reports.
2. In the Design Tab, right click on left side of the Report Designer to display the context menu.
3. From the context menu click Design > Printer Setup. Using the Printer Setup dialog select the appropriate printer or select "No Printer" option in the upper left corner of the dialog
  • TAC INET
  • 7730
