Replacing a Satchwell MBF 2730 2 1/2" 3-Port valve.
  • Replacing a Satchwell MBF 2730 2 1/2" 3-Port valve.
  • sesa125819
    sesa125819
‎2018-09-06 01:52 PM
Replacing a Satchwell MBF 2730 2 1/2" 3-Port valve with a current version.
MBF 2730
MBF 4732.
The Satchwell MBF 2730 was an imperial valve and the replacement MBF 4732 is metric, so there will be differences in size.
The Satchwell MBF 2730 was an imperial 2 1/2" valve, this valve is replaced by a MBF 4732 65mm version, therefore there are some differences in size, the following table shows details of this valve.
 Below are details of the current range of MBF valves.
  • Field Devices
  • 5176
