Replacement of Satchwell "MM" combined Actuator & 3-port Valve Body assembly due to obsolescence.
  • Replacement of Satchwell "MM" combined Actuator & 3-port Valve Body assembly due to obsolescence.
  • CraigEl
    CraigEl
‎2018-09-10 04:55 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-14 08:55 PM
Satchwell “MM” combined Actuator & 3-port Valve Body assembly requires replacement.
Field Devices
Stand alone Satchwell “MM” combined Actuator & 3-port Valve Body assembly.
MM
Actuator
3-port
Valve Body
Obsolescence of Satchwell “MM” combined Actuator & 3-port Valve Body assembly.
Replace Satchwell “MM” combined Actuator & 3-port Valve Body assembly with Schneider Electric MD10B Actuator, LMD-MB Linkage Kit and Satchwell MB series 3-port Valve Body of appropriate size.
Details of the original Satchwell “MM” combined Actuator & 3-port Valve Body assembly may be viewed here.
Details of the replacement Schneider Electric MD10B Actuator may be viewed here.
Details of the replacement Schneider Electric LMD-MB Linkage Kit may be viewed here.
Details of the replacement Satchwell MB 3-port Valve Body may be viewed here.
N.B.
It is possible that the "MM" Actuator may have been fitted with an Auxiliary Switch.
If so then an MD-S1 Auxiliary Switch may be fitted to the MD10B Actuator if required.
Details of the MD-S1 Auxiliary Switch may be viewed here.
  • Field Devices
  • 6626
