Replacement of Satchwell "M 1301" Actuator forming part of combined Actuator / 3-port Valve Body assembly due to obsolescence.
  • Replacement of Satchwell "M 1301" Actuator forming part of combined Actuator / 3-port Valve Body assembly due to obsolescence...
  • CraigEl
    CraigEl
‎2018-09-10 05:27 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-11 10:00 PM
Satchwell "M 1301" Actuator forming part of combined Actuator / 3-port Valve Body assembly requires replacement.
Field Devices
  • Stand alone Satchwell “M 1301” Actuator forming part of combined Actuator / 3-port Valve Body assembly
  • M 1301
  • Actuator
  • 3-port
  • Valve Body
Obsolescence of Satchwell "M 1301" forming part of combined Actuator / 3-port Valve Body assembly.
There is no direct replacement for the "M 1301" Actuator and as a result both the "M 1301" Actuator and the 3-port Valve Body to which it is connected will also require replacement.
Replace Satchwell “M 1301” combined Actuator & 3-port Valve Body assembly with Schneider Electric MD10B-230 Actuator, LMD-MB Linkage Kit and Satchwell MB series 3-port Valve Body of appropriate size.
Details of the original Satchwell “M 1301” combined Actuator & 3-port Valve Body assembly may be viewed here.
Details of the replacement Schneider Electric MD10B-230 Actuator may be viewed here.
Details of the replacement Schneider Electric LMD-MB Linkage Kit may be viewed here.
Details of the replacement Satchwell MB 3-port Valve Body may be viewed here.
N.B.
It is possible that the "M 1301" Actuator may have been fitted with an Auxiliary Switch.
If so then an MD-S1 Auxiliary Switch may be fitted to the MD10B-230 Actuator if required.
Details of the MD-S1 Auxiliary Switch may be viewed here.
  • Field Devices
  • 6679
