Replacement for valve V392
  • Replacement for valve V392
  • SESA150559
    SESA150559
  • sesa125819
    sesa125819
‎2018-09-06 12:19 PM
Since the V392 is no longer available, a replacement valve is requested.
V392
Forta
Replacing old V392 valve.
No direct replacement is available. Closest in application should be V311T with a Forta actuator, but it will require pipe work to fit.
To review the V392 data sheet, please click HERE.
  • Field Devices
  • 8092
