Replacement for Satchwell DR2253 Temperature Sensor due to obsolescence.
  • Replacement for Satchwell DR2253 Temperature Sensor due to obsolescence.
  • sesa125819
    sesa125819
‎2018-09-06 12:11 PM
Replacement for Satchwell DR2253 Temperature Sensor.
Satchwell
Sensor
DR
DR2253
Obsolescence of Satchwell DR2253 Temperature Sensor.
The Satchwell DR2253 Temperature Sensor is replaced with the Schneider Electric STR614 Temperature Sensor.
The Schneider Electric STR614 provides the same functionality as the Satchwell DR2253, differing only in its appearance, dimensions and terminal identification.
The Schneider Electric STR614 terminals are not polarised.
  • Field Devices
  • 8230
