Replacement for Satchwell DDT0001 Duct Temperature Sensor due to obsolescence.
  • Replacement for Satchwell DDT0001 Duct Temperature Sensor due to obsolescence.
  • sesa125819
    sesa125819
‎2018-09-06 12:12 PM
Replacement for Satchwell DDT0001 Duct Temperature Sensor.
Satchwell
Sensor
DDT
DDT0001
Obsolescence of Satchwell DDT0001 Duct Temperature Sensor.
Replace Satchwell DDT0001 Duct Temperature Sensor with Schneider Electric STD660 Duct Temperature Sensor.
The Schneider Electric STD660 provides the same functionality as the Satchwell DDT0001, differing only in its appearance, dimensions and terminal identification.
The Schneider Electric STD660 Terminals are not polarised.
  • Field Devices
  • 8213
100% helpful (1/1)
