Replacement for Drayton A703 Immersion Temperature Sensor by S-E STP600D
  • Replacement for Drayton A703 Immersion Temperature Sensor by S-E STP600D
  • sesa125819
    sesa125819
‎2018-09-07 04:26 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-30 10:47 AM
Field Devices
Drayton A703 Immersion Temperature Sensor installation.
Obsolescence of Drayton A703 Immersion Temperature Sensor
1.  Replace Drayton A703 Immersion Temperature Sensor with S-E STP600D
The S-E STP600D provides the same functionality as the Drayton A703, differing only in its appearance and dimensions.
The S-E STP600D Terminals are not polarised.
N.B.
It should be noted that the S-E STP600D is not supplied with a compatible Pocket.
If it is not possible to utilise the existing Drayton Pocket, then a 100mm S-E Pocket (9121041000-Brass or 9121051000-Stainless Steel) should be selected as appropriate and in order to comply with the system requirements.
There is a intentional gap between the top of the pocket, and the sensor housing, to ensure the probe tip touches the end of the pocket.
  • Field Devices
  • 3269
