Replacement battery for IAC-TS and IAC-600
  • Replacement battery for IAC-TS and IAC-600
  • Gary
    Gary
  • CraigEl
    CraigEl
‎2018-09-06 01:04 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-15 07:31 PM
Need to purchase and replace the battery for the IAC-TS and IAC-600.
Satchwell MicroNet
  • IAC-600
  • IAC-TS
The battery has failed and requires replacement.
The battery is a lithium crystal SNAPHAT M4T28-BR12SH1
  • These are available from RS Components.
  • The RS Components stock number is 189-1239.
  • Manufacturer name: STMicroelectronics
  • Manufacturer's part number: M4T28-BR12SH1
Specifications
Category Detachable Lithium Power Source
Maximum Operating Temperature 70°C
Minimum Operating Temperature 0°C
Mounting Through Hole
Pin Count 4
Product Height 8mm
Product Length 21.84mm
Product Width 18.03mm
Supplier Package SNAPHAT
Documentation
  • M4T28-BR12SH M4T32-BR12SH TIMEKEEPER SNAPHAT (battery and crystal) Data Sheet.pdf
  • Statement of conformity.pdf
  • Satchwell MicroNet
  • 6802
100% helpful (1/1)
