Replacement Stuffing Box for a TAC VTRA control valve
  • Replacement Stuffing Box for a TAC VTRA control valve
  • DavidChild
    DavidChild
  • sesa125819
    sesa125819
‎2018-09-06 09:06 AM
VTRA valve is leaking and requires a stuffing box
Field Devices
  • VTRA
  • Stuffing Box
  • 080488305
  • 0804883005
The data sheet indicates that the replacement part number is 080488305, but that part number is not found.
The VTRA data sheet indicate that the Stuffing Box part number is 080488305, but this incorrect.
The correct part number is 080-4883-005, for ordering purposes the part number 0804883005 without the hyphens (-) may have been used.
  • Field Devices
  • 17681
