Remove I/NET Seven software and SQL database from a stand-alone PC, then install a later version
  • Remove I/NET Seven software and SQL database from a stand-alone PC, then install a later version
  • sesa139513
    sesa139513
  • CraigEl
    CraigEl
‎2018-09-06 11:42 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 01:34 AM
Steps to remove I/NET Seven software and SQL database from a stand-alone PC, then install a later version of I/NET Seven
TAC INET
  • I/NET site
Need to replace existing I/NET software on a computer.
  1. Remove I/NET Seven and MSDE using the Add & Remove Programs utility in Windows Control Panel.
  2. Go to Windows Explorer and delete the I/NET Seven and SQL Microsoft Server folders.
  3. Go to the Icon called “My Computer” / Manager / Local Users / User / and delete the file called “INMProxy”.
  4. Empty the Windows Recycle Bin before beginning the new install.
Check compatibility by using Software and Firmware compatibility matrix for older versions of the traditional product lines.
  • TAC INET
  • 1243
