Remote/External Sensor compatibility with SE7000 series Room Controllers
Select a Country
  • Remote/External Sensor compatibility with SE7000 series Room Controllers
‎2018-09-11 02:36 PM
Last Updated: ContentModerator Explorer ‎2025-10-15 03:39 AM
Installing a SE7652A5045P and want to add an outside air and supply air temperature sensor.  What type of sensor is accepted?
EcoStruxure Building Operation, EcoStruxure Building Expert
• Building Operation Workstation
• Building Operation Automation Server
• SSL SE7000
Spec requirement
The SE7000 series sensor can take any 10k ohm NTC thermistor (type 2).
For a temperature/resistance chart, see page 6 in this guide.
For a Schneider-Electric compatible sensor, see page 7.
  • EcoStruxure Building Expert
Tags (5)
  • 16268
  • RamaAly22
  • se7600a5000
  • se7600a5000b
  • se7600a5000e
0% helpful (0/1)
