Recovering a Continuum database without a SQL Backup (BAK) from the ContinuumDev.MDF and ContinuumLog.LDF files.
  • Recovering a Continuum database without a SQL Backup (BAK) from the ContinuumDev.MDF and ContinuumLog.LDF files.
  • Alan_Wood
    Alan_Wood
  • sesa116832
    sesa116832
‎2018-09-10 07:54 AM
A hard drive failure on the LAN SQL server or on a Stand Alone workstation is preventing Cyberstation from starting.
LAN Server and StandAlone workstations
A hard drive failure on the LAN SQL server or on a Stand Alone workstation is preventing Cyberstation from starting. The site does not have a verified SQL backup of the database. The raw data files, typically named ContinuumDev.mdf and ContinuumLog.ldf, can be recovered.
For a standalone, use the Microsoft SQL Server 2005 Management Studio Express. The freeware SQL front end is much easier to use than the command line. The Microsoft SQL Server 2005 Management Studio Express will also allow you to administer SQL 2000 MSDE databases.
The Management Studio Express can be downloaded for free from Microsoft using the link below.
http://www.microsoft.com/downloads/details.aspx?FamilyID=c243a5ae-4bd1-4e3d-94b8-5a0f62bf7796&Displa...
 This procedure assumes that the Continuum database no longer exists on the SQL Server. It is also critical that SQL is up and running.  If the SQL Server or StandAlone workstation hard drive has crashed, SQL must be reinstalled on a functioning workstation before attempting to attach the raw data files. See the link below for the steps to attach the db using the SQL Management Studio Express
http://msdn.microsoft.com/en-us/library/ms190209.aspx
 This links to an article that describes how to attach the data files and of the log files for a database running Microsoft SQL Server 2005, SQL Server 2000, or SQL Server 7.0 database.
http://support.microsoft.com/kb/224071
  • 7463
