RH-Series Humidity Sensor Wiring Clarification
  • RH-Series Humidity Sensor Wiring Clarification
  • RobertAndriolo
    RobertAndriolo
  • AbeMeran
    AbeMeran
‎2018-09-06 09:26 AM
Warning
Electrostatic Discharge Required: Always discharge static electricity from your person by touching metal prior to handling any hardware. Failure to do so may result in damage to devices.
Confused by RF-Series sensor wiring instructions.
Do the controller's input return and the supplied power ground connect to the same termination on the sensor?
RH-Series sensor
Documentation
*** If connecting to a voltage input on the controller then use the VOUT termination instead of the 4-20 mA
Labels (3)
  • Field Devices
Tags (2)
  • 16871
  • rh_series
