Power Over Ethernet with Andover Continuum Controllers
  • Power Over Ethernet with Andover Continuum Controllers
  • PeterEdvik
    PeterEdvik
  • mroche1
    mroche1
  • sesa139513
    sesa139513
  • JohnBoehmer
    JohnBoehmer
‎2018-09-07 01:26 AM
Last Updated: Lt. Commander mroche1 Lt. Commander ‎2022-05-18 09:10 AM
While Continuum controllers and EcoStruxure controllers do not utilize Power over Ethernet (POE), can plugging in a Continuum or EcoStruxure controller into a POE switch damage either the POE port or the controller?
Andover Continuum, EcoStruxure Building Operation
  • PoE
  • Ethernet
Controllers must be installed on a subnet served by a POE switch.
  • According to the IEEE standard, a POE switch shall determine if the connected device is POE capable before turning on the power.
  • The detection if a connected unit is POE capable is done by measuring the resistance between the pair #2 - #3 and pairs #1 - #4.
  • On a POE capable unit the resistance is 25kohm, with some tolerance. If it is lower or higher it is not considered to be POE capable.
  • As there are no Continuum or EcoStruxure ethernet controllers that apply a 25K ohm load, a properly functioning switch port will not enable PoE power and the device will not be damaged.
Find information on the PoE standard in the Fundamentals of Power Over Internet (PoE) PDF
Labels (2)
Tags (2)
  • 3155
  • PeterEdvik19
100% helpful (2/2)
