Ports on a 7793 MCI
  • Ports on a 7793 MCI
  • Roger_Bently
    Roger_Bently
Ports on a 7793 MCI
‎2018-09-06 02:06 PM
The A and B Channels used to communicate to Sublan devices need to interface with FOI (Fiber Optic Interface) devices, but not sure what speed it communicates on or what setting it should be.
I/NET Seven Controller Lan on a 7793 MCI.
Setting up a 7793 Controller to communicate to a FOI.
On a 7793 MCI, there are several ports that are used for communication to various devices. These ports are:
  1. A standard synchronous RS485 controller LAN Port.
  2. Two standard asynchronous RS485 sub-LAN Ports.
  3. Two asynchronous RS232 ports, one used for the HHC Console and the other for Direct Connect to a PC.
  4. An optional plug on-board with an RS232 synchronous connection used for an external modem.
  • TAC INET
  • 4658
