Points not working when the MR Copy Feature is used
  • Points not working when the MR Copy Feature is used
  • sesa139513
    sesa139513
  • Roger_Bently
    Roger_Bently
‎2018-09-06 03:08 PM
Points which were created using the MR Copy feature are not working, whether it was offline or not.
This is also true for points that have been working fine for a long time and then suddenly stop.
I/NET Site
First verify that it is not a hardware failure like thermistors and sensors.
There is a work around to this:
  1. Delete the points that have been copied through the MR Copy feature.
  2. Now, re-add them again through Resident I/O Points.
  3. Go to controller summary and verify that the point is now functioning properly.
  • TAC INET
  • 1896
