Plain English script local array issue.
  • Plain English script local array issue.
  • CraigEl
    CraigEl
  • AbeMeran
    AbeMeran
‎2018-09-07 08:46 AM
Referring to a local array by name in Plain English references data element one ([1]) instead of data element zero ([0]) as is the case when the array is a global point or value.
In the example below, setting theArray and setting theArray[1] is actually the same, the value 10 is overwritten by the value 20
Enterprise Server - ES
Automation Server - AS
CyberStation
CX
b3
i2
Function as designed.
This is the way Plain English works, the ability to access data element one ([1]) by just naming the array is provided for convenience.
Labels (2)
  • 14594
100% helpful (1/1)
