Plain English Function does not work.
  • Plain English Function does not work.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:15 AM
When the sample code supplied under Continuum Help for the Select Case function is pasted directly into a program a controller the function does not work.
Continuum generates the following error.  "Process not supported"
  • Plain English functions
  • Select Case
Some PE functions are supported in specific Continuum products only.
For example, Select Case is supported only in CyberStation.
Check the Products Supported section of the Continuum Help on Select Case functions.
Select case is supported in CyberStation only.
  • 13777
