Pinpoint fails to open or some parts of a graphic will not work
  • Pinpoint fails to open or some parts of a graphic will not work
  • sesa116827
    sesa116827
  • Alan_Wood
    Alan_Wood
‎2018-09-06 02:17 PM
Pinpoint will not open on one workstation or some parts of a graphic will not work
  • Continuum
  • Windows XP
  • Windows Vista
  • Windows 7
  • Windows Server 2003
  • Windows Server 2008
Due to Microsoft updates, file redirection and/or file corruption, Pinpoint will not open when the configuration / ini file is damaged or corrupt. The points or the whole controller may need to be reloaded.
  1. Shut down Continuum
  2. Open MS Explorer
  3. Path to C:\WINDOWS
  4. Delete Pinpoint.ini
  5. Start Continuum (Starting Continuum will recreate the file)
  6. Ensure that user account control slider is turned off and/or Write/Read permissions are granted to the C:\program files\Continuum folder
  7. Reload individual points or reload the entire controller(if the issue is isolated to certain points)
  8. If these steps do not work, Go to Windows Control panel and uninstall/reinstall Pinpoint
  • 4313
