Permanently unlock Door with Triple Badging at the Door
  • Permanently unlock Door with Triple Badging at the Door
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
Guinan AdamSteele Guinan
‎2019-11-11 01:46 AM
Require method on how to latch unlock a Door by Triple Badging.
EcoStruxure Security Expert
Security Expert
Require Door to be controlled normally with card access but also to allow a valid User to latch unlock the Door with three consecutive valid badges.
Required Objects
  • virtual Output - Flag to trigger latching (v_TripleBadgeLock)
  • Programmable Function - Latches Door when virtual output ON (Door_UnlockLatch)
  • Programmable Function - Unlatches when virtual output OFF (Door_UnlockLatch_Restore)
  • Door - Door to control (MainEntrance)
Configuration
  1. Create virtual Output v_TripleBadgeLock. Set Module Type to Output (PX) and Module Address and Module Output channel to ones that do not exist.
    Virtual OutputVirtual Output
  2. On the Reader Expander > Reader 1 tab
    - Set Reader 1 Arming Mode to Toggle Function Output on 3 Reads
  3. Set Reader 1 Function Output to v_TripleBadgeLock
    Reader Expander - ConfigurationReader Expander - Configuration
  4. Go to Automation > Programmable Functions and create Door_UnlockLatch
    - Set Type to Door Control
    - Set Mode to Normal
    Programmable Function - GeneralProgrammable Function - General
  5. Under Door Control tab
    - Set Door Function Mode to 2 - Follow Pulse On Output
    - Set Door Control Mode to 1 - Latch Door Unlock
    Set Output To Check to v_TripleBadgeLock
    Set Door To Control to MainEntrance
    - Save changes
    - Right-click Door_UnlockLatch function and select Start
    Programmable Function - UnlockLatch - Door ControlProgrammable Function - UnlockLatch - Door Control
  6. Go to Automation > Programmable Functions and create Door_UnlockLatch_Restore
  7. Under Door Control tab
    - Set Door Function Mode to 5 - Inverted Follow Pulse Off Output
    - Set Door Control Mode to 0 - Emulate Unlock Menu
    - Set Output To Check to v_TripleBadgeLock
    Save changes
  8. Right-click Door_UnlockLatch_Restore function and select Start
    Programmable Function - Unlatch - Door ControlProgrammable Function - Unlatch - Door Control
  • EcoStruxure Security Expert
  • AdamSteele23
