PIR functionality/ordering options SE7300 series controllers
  • PIR functionality/ordering options SE7300 series controllers
  • SESA150559
    SESA150559
‎2018-09-06 10:58 AM
What is included when the PIR option is ordered?
The SE7300 series controllers can be ordered both with and without the PIR option
If the PIR sensor functionality is ordered as included from factory, code 55 (example: SE7600A5545E) should be used.
If PIR functionality is not required, code 50 (example: SE7600A5045E) should be used.
PIR functionality can be retrofit at any time. For details and part numbers, please see related documentation.
Labels (7)
  • EcoStruxure Building Expert
  • Field Devices
  • Satchwell BAS & Sigma
  • TAC IA Series
  • 11504
