PCU/SLI controller went to Boot State after direct connect with PC
  • PCU/SLI controller went to Boot State after direct connect with PC
  • CraigEl
    CraigEl
‎2018-09-06 11:32 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 04:41 PM
PCU/SLI controller went to Boot State after direct connecting a CBL 072 cable from the controller to a PC/Laptop.
TAC INET
  • PCU
  • SLI
  • CBL072 cable
Cable connections have most likely been reversed.
  1. The longer of the two female (9 pin) connectors must plug into the PC.
  2. The shorter of the two (9 pin) female connectors connects to the serial port of the controller.
  3. Label the connectors for future reference.
  4. If this does not correct the problem, check the cable wiring or replace the cable. For pin-out information and illustration on how to connect the cable, refer to the appropriate Controller TCON.
  • TAC INET
  • 1162
