PCT 2.0 memory usage calculation
  • PCT 2.0 memory usage calculation
  • StephenYang
    StephenYang
Admiral StephenYang Admiral
‎2024-08-06 11:14 AM
Last Updated: Picard RobertAndriolo Picard ‎2024-08-06 04:32 PM
How to calculate memory needed for PCT.
Project Configuration Tool.
Unclear memory usage in PCT.
  1. The specifications show that the PCT default memory is 8 GB in Hyper-V. Each running PCT server takes 2 GB and 170 MB per running server. A 4-core CPU can run up to approximately 100 servers and an 8-core CPU can run up to approximately 200 servers.
  2. Memory Usage calculation example:
    For 23 servers, i.e. 23*0.170 GB + 2 GB = 6 GB
    For 36 servers, i.e. 36*0.170 GB+ 2 GB = 8 GB (default)
    For 47 servers, i.e. 47*0.170 GB+ 2 GB = 10 GB
    To start 100 servers, 100*0.170 GB+ 2 GB = 19GB
Helpful Link:
PCT 2.0 memory configuration in Hyper-V
Labels (2)
  • Project Configuration Tool
  • StephenYang24
100% helpful (3/3)
