Optimum Living Space Sensor showing blank LCD
  • Optimum Living Space Sensor showing blank LCD
  • RandyDavis
    RandyDavis
  • JonGreen
    JonGreen
  • Jonathan
    Jonathan
Commander JonGreen Commander
‎2020-09-16 07:09 AM
on ‎2020-09-16 07:09 AM
After connecting a new Optimum Living Space Sensor, the LCD is blank other than being backlit.
  • Building Operation SmartX Living Space Sensor Optimum
  • Building Operation Multi-purpose VAV fw 2.00.03.02000 or older
Only Living Space Sensor bases running application version 1.0 or later can read the Optimum cover models
Upgrade EBO to v3.1.x or later and SmartX controller to fw v3.01.x or later. At the time of this being published, firmware revisions prior to 3.01.x are not compatible with the Optimum Living Space Sensors (SXWSCDPSELXB, SXWSCDPSELXW, SXWSCDXSELXB, SXWSCDXSELXW).
Tags (3)
  • 45906
  • JonGreen20
  • optimum
