Operation was not performed error when accessing logs in Continuum 1.9
  • Operation was not performed error when accessing logs in Continuum 1.9
  • Alan_Wood
    Alan_Wood
‎2018-09-06 01:05 PM
The operation was not performed error pops up when accessing logs or extended log via a group with Continuum 1.9
Continuum
Webclient
Windows XP
Windows Vista
Windows 7
Windows Server 2003
Windows Server 2008
The installation was accomplished according to the instructions in the readme file to rename the original logviewer.exe
Shutdown Cyberstation
Install 1.90 SP1 first
Copy in the AccSQLSP.dat from the hotfix and upgrade the database
Delete all the original logviewer.exe files then copy in the new logviewer.exe from the hotfix. Just renaming the file will not work.
Reboot the PC and restart Continuum and the error should no longer appear.
  • 6580
