Opening the Xenta 102-AX plug-in results in "request for LonMark Object status" error
  • Opening the Xenta 102-AX plug-in results in "request for LonMark Object status" error
  • Cody_Failinger
    Cody_Failinger
‎2018-09-10 12:53 PM
When the Xenta 102-AX plug-in is opened the following error is given, “Reply to ‘request for LonMark Object status’ message was not received”
  • LonMaker
  • NL220
  • 102-AX Plug-in
There is a bug in the certain beta versions of the LonMark/Echelon DRF-kit. LonMark resource files 13.04 and 13.10 will not work with the Xenta 102-AX plug-in.
The solution for the Xenta 102-AX plug-in error is to install a LonMark resource file version other than 13.04 or 13.10.
  1. Shut down LonMaker
  2. Go to add and remove programs. Uninstall LonMark Resource Files (13.04 or 13.10).
  3. Go to http://www.lonmark.org/technical_resources/resource_files/
  4. Download the latest LonMarkResourceFilesXXXX.exe
  5. Run the executable.
  6. Restart LonMaker. Verify that the 102-AX plug-in works without errors.
  • 7409
