Opening files from a graphic in TAC Vista Workstation and TAC Vista Webstation
  • Opening files from a graphic in TAC Vista Workstation and TAC Vista Webstation
  • CraigEl
    CraigEl
  • Jonas_Brissman
    Jonas_Brissman
  • Benji
    Benji
  • Sacco
    Sacco
‎2018-09-07 04:52 AM
Last Updated: Administrator CraigEl Administrator ‎2025-08-28 09:38 PM
Users are unable to open files from a TGML graphic in TAC Vista Webstation using the OpenFile command.
Product line
TAC Vista
  • Vista Webstation
  • Vista Workstation
The OpenFile command is not supported in web browsers, which prevents documents from opening directly in Webstation.
To enable file access from TGML graphics in both Workstation and Webstation, follow these steps:
In TAC Vista Workstation
  • Use the OpenFile button as usual.
  • Files (PDF, DOC) open without issues.
In TAC Vista Webstation
  • The OpenFile command does not function in a browser.
  • Instead, define a hyperlink in TAC Vista:
    • Place the document in the server folder:
      C:\Inetpub\wwwroot
    • Use the format:
      http://<ip_address>/<docName>
Typical Graphic Behavior
Document Type Workstation Behavior Webstation Behavior
PDF Opens normally Opens in same window (even with _blank target)
DOC Opens in extra window (must be closed manually) Opens normally
Additional Resources
For an alternative way of viewing the reports and other files, refer to TAC Vista - Web Reports - Schneider Electric Community
Tags (2)
  • 3681
  • JonasBrissman25
