Open time schedule in OGC graphic from Webstation.
  • Open time schedule in OGC graphic from Webstation.
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 10:35 AM
Is it possible to open a time schedule from a OGC graphic when the graphic is opened from Webstation?
TAC Vista 5.1.x
In older versions of TAC Vista a "Command Point" object could be used to link to a time schedule and it worked fine in booth Webstation and Workstation.  And that still works fine in Workstation but to get it to work in later versions(5.1.x) a "Dynamic Value" object must be used in the graphic editor to get it to work in Webstation.
Use a "Dynamic value" object in the OGC editor when linking to a time schedule to get it to work in TAC Webstation.
  • 12718
