Objects with a "." character at the end of the object name will not bind to other objects.
  • Objects with a "." character at the end of the object name will not bind to other objects.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 12:19 PM
Cannot bind an input with the name Intern.Temp.
  • StruxureWare Building Operation
  • Binding
  • Point Naming
While a "." may be used as a separating character within a point name, it is an illegal object name character when it appears as the last character.
StruxureWare Building Operation will generate an Illegal Character error when you attempt to name an object with a trailing "." character.
Rename the object without a "." at the end of the name string and rebind it to the object.
  • 8001
