OP panel shows a ! after a value
  • OP panel shows a ! after a value
  • RandyDavis
    RandyDavis
  • MikaelKrantz
    MikaelKrantz
  • sesa150561
    sesa150561
‎2018-09-06 08:46 AM
Last Updated: Guinan RandyDavis Guinan ‎2019-09-27 12:16 PM
TAC Vista, EcoStruxure Building Operation
  • Xenta OP
  • Vista
  • Struxureware
If you have a binary value in OP panel, and you connect an analog value to it, the OP will show the "!"
Edit the OP Panel tree, disconnect the analog value and attach a binary value instead.
Generate and save the application.
Labels (2)
Tags (2)
  • 18058
  • MikaelKrantz19
