ODBC SQL Server Driver error updating to 1.94 SP1
  • ODBC SQL Server Driver error updating to 1.94 SP1
‎2018-09-11 06:51 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:53 AM
A database update from 1.94 to 1.94 SP1 will generate an Installation error [Microsoft][ODBC SQL Server Driver][SQL Server Implicit conversion from data type datetime to int is not allowed
Andover Continuum
  • Continuum
  • Windows XP
  • Windows 7
  • Windows Server 2003
  • Windows Server 2008
A column in the db doesn't get converted properly. The SQL Server Implicit conversion from data type 'datetime' to 'int' is not allowed. The CONVERT function has to be used to run this query contained in the hotfix.
1. To correct this issue apply the following hotfix AFTER installing 1.94 SP1 but BEFORE running the database update
2.  Locate the hotfix on Exchange using the following link:  https://ecobuilding.schneider-electric.com/search#keyword/14191/tab/documents
3.  Find the item entitled:  "Error when Updating the Continuum DB while Upgrading to CyberStation 1.94 SP1 - TPA-CONT-13-0003.00"
4. Select download and read the release notes and install the hotfix
Tags (2)
  • 15297
  • RamaAly25
